Первый Эпик в Питере!
Сообщение BWN » 29 июл 2008, 10:58
Первый в моей жизни новый велос из магазина.
До этого были: 1. Детский спорт: стартон, стартон, рекорд, рекорд, тахион
Любительский фитнес: Cannondale sm 700, Scott Comp Racing 2003
Спекуха - стандарт, я противник всяких там апгрейдов-)
FRAME Epic FSR M5 alloy, fully manipulated frame w/ new larger diameter/stiffer ORE DT/TT, hollow alloy shock link, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
REAR SHOCK Specialized AFR inertia, Brain Fade, adjustable from HT firm to Trail Tune, air spring, rebound adjust
FORK Fox F100 RL, 100mm travel, air spring, rebound/compression adjust w/ lock out, alloy steerer
HEADSET 1 1/8" threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STEM Specialized adjustable rise, 31.8mm clamp, 3D forged w/CNC finish
HANDLEBARS Specialized XC low rise 31.8mm bar, 2014 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
TAPE/GRIPS Specialized thin lock on grip, dual density
FRONT BRAKE Custom Avid Ultimate 7, hydraulic disc, 160 and 185mm rotor
REAR BRAKE Custom Avid Ultimate 7, hydraulic disc, 160mm rotor
BRAKE LEVERS Custom Avid Ultimate 7, hydraulic disc
FRONT DERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
REAR DERAILLEUR SRAM X-0, 9-speed, mid cage
SHIFT LEVERS SRAM X-9, aluminum 9-speed trigger
CASSETTE FREEWHEEL Shimano HG-50, 9-speed, 11-34t
CHAIN SRAM PC-971 w/ Power Link
CRANKSET Shimano M762 XT custom for Specialized
CHAINRINGS 22S/32A/44A, 4 bolt 104/64mm
BOTTOM BRACKET Shimano M762 XT custom for Specialized
PEDALS Crank Brothers Smarty custom for Specialized
RIMS DT Swiss custom for Specialized X420, 24mm w/ eyelets, 28/32h
FRONT HUB Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
REAR HUB DT Swiss custom for Specialized 370 with DT RWS QR, 32h
SPOKES DT Swiss Competition 1.8/1.6mm
FRONT TIRE Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
REAR TIRE Specialized Fast Trak Control LK, 26x2.0", 60TPI, tubeless ready aramid bead, dual compound
TUBES Specialized Ultralite, .6mm, presta
SADDLE Specialized XC MTB, hollow Cr-Mo rails, SL foam
SEAT POST 2014 butted alloy, single bolt setback, 30.9 x 350/400mm
SEAT BINDER Alloy collar w/ QR, 34.9mm clamp ID
NOTES Protective clear coat, derailleur hanger, reflectors, owners manual
Замены:
Педали на ХТ новые поменял
В планах кассета, передний переклюк
ЭТО МОЗГ!
еще фото http://photofile.ru/users/bwn/135122286/
Последний раз редактировалось BWN 19 фев 2009, 17:54, всего редактировалось 13 раз.
Сообщение Miha » 29 июл 2008, 11:00
зелный это тренировочный?
Сообщение BWN » 29 июл 2008, 11:04
да, с колесиками чтоб не страшно было
тоже спеш-)
Сообщение Andrey Nikolaevich » 29 июл 2008, 11:40
Вася, поздравляю!
ПС Как там нащот оздоровительных тренировок? :D
Сообщение BWN » 29 июл 2008, 11:42
Andrey Nikolaevich писал(а):Вася, поздравляю!
Спасибо, Андрей Николаевич, конечно
но поздравлять пока не с чем
Планируется!-) Оздоровливаться я начал-)
пока держусь-)
А ты сейчас в какой форме? очень быстро катаешься?-)
пиши в личку - будем думать
Сообщение Andrey Nikolaevich » 29 июл 2008, 11:45
Как обычно. Медленно :D
Ты бы рассказал - как он катит, где брал, скока весит, ну и т.д.
Сообщение BWN » 29 июл 2008, 11:49
Andrey Nikolaevich писал(а):Как обычно. Медленно :D
брал у субдилеров спеша питерских по предзаказу, договор составлял
катит не знаю как - я плохо качу-)
но думаю ДОЛЖЕН КАТИТЬ! За такие-то деньги-))
весит примерно 12,5
Пс как обычно медлено мне ПОКА не подходит
надо совсем медленно :D
Сообщение BWN » 29 июл 2008, 11:58
Да, правила форума требуют указать предназначение аппарата:
Фитнес райдинг, "группа здоровья", похудение-)
mal4ik
Сообщение mal4ik » 29 июл 2008, 14:49
а пачиму устаревший спеш ?
Сообщение Timur (Alma-Ata) » 29 июл 2008, 15:01
для похудения самое оно - будет сматреть на новый и худеть! :)
Сообщение Bujhm » 29 июл 2008, 16:45
Крута! Хоть внешне он мне и не нравицца, но внушает! Дашь попробовать как-нть при случае? :roll:
Сообщение Олег » 30 июл 2008, 00:14
Игорь писал(а):Дашь попробовать как-нть при случае? :roll:
Велик не женщина, чего его пробовать-то...
Станислав
Сообщение Станислав » 30 июл 2008, 08:39
не слабо для фитнесса!!! :), интересно каков он в сравнении с пердыдущими
Сообщение BWN » 01 авг 2008, 14:45
mal4ik писал(а):а пачиму устаревший спеш ?
Тимур уже ответил.
К тому же этот классический Эпик - общепризнанный один из лидеров среди двухподвесов, а новый пока никто не видел.
К тому же новый будет только к лету 2009, я к тому времени бы так уже потолстел, что похудеть будет трудно.
Сообщение BWN » 01 авг 2008, 14:48
Игорь писал(а):Крута! Хоть внешне он мне и не нравицца, но внушает! Дашь попробовать как-нть при случае? :roll:
1. Я тебя пока включил заочно в элитную "группу здоровья". Готовься!-)
2. Я один раз взял "попробовать", потом месяц в больнице лежал со сломанным носом-) Чужой велик дело такое.
мудро
Сообщение BWN » 01 авг 2008, 14:54
Станислав писал(а):не слабо для фитнесса!!! :), интересно каков он в сравнении с пердыдущими
почему не слабо?-)
для фитнеса как-раз "только-только" -)
Re: Первый Эпик в Питере!
Сообщение BWN » 15 фев 2009, 21:18
Статистика по Эпикам в Питере.
По моим сведениям в Питере появилось еще 2 "классических" Эпика 2008 года
- на модель ниже Epic Comp
- на модель выше Epic Marathon (у известного в наших кругах коллеги с veloroad)
Alenka
Сообщение Alenka » 16 фев 2009, 20:01
Ну... не знаю как там Ваша статистика, а, если покопаться, то в Питере Эпиков в достатке ))))
Я вот посмотрела, у меня на балконе какой-то валяется... )))))
И вообще, я считаю, что двухподвесы - это для девушек, чтоб удобней было. ИМХО.
AZ
Сообщение AZ » 16 фев 2009, 20:10
Да, девушки могут быть жестокими:)
Сообщение MABP » 16 фев 2009, 21:11
Я бы уже выбросил... :-)
Сообщение BWN » 16 фев 2009, 21:22
Alenka писал(а):если покопаться, то в Питере Эпиков в достатке ))))
возможно, пишу о тех, что знаю
может их и достаточно, но где они - никто не знает
Alenka писал(а):Я вот посмотрела, у меня на балконе какой-то валяется... )))))
У наших людей Эпики на балконе не валяются. И на такси они в булочную не ездят-))
А что за модель, если не секрет?
Alenka писал(а):И вообще, я считаю, что двухподвесы - это для девушек, чтоб удобней было. ИМХО.
Ну тогда как минимум процентов 50 кросс-кантрийцев и хс-марафонцев по Вашему тоже девушки?)))
И вообще - EPIC это для Мужчин.
А для девушек - Era.
Alenka
Сообщение Alenka » 17 фев 2009, 19:56
Ребята! Не обижайтесь!
Эпик - это один из лучших велосипедов, во всех своих проявлениях! ;)
Нас немного, но мы ЕСТЬ! )))
Вел собран на раме Epic S-Works 2007.
Только Specialized (в предыдущие годы) мог выпустить командный Эпик розового цвета. Говорю же, для девушек... :ya_hoo_oo:
Сообщение BWN » 17 фев 2009, 20:25
Alenka писал(а):Нас немного, но мы ЕСТЬ! )))
Вот еще - обижаться-))
Клёво! Есть Эпики в петербургских селеньях!-)
До встречи на лесных стадионах! :-):
Alenka писал(а):Только Specialized (в предыдущие годы) мог выпустить командный Эпик розового цвета. Говорю же, для девушек... :ya_hoo_oo:
Был такой, но каталась на нем совсем не девушка-) Не знаю, чего их поперло.
А вот на картинке выше ERA (женская версия Эпика).
Сообщение Bujhm » 01 мар 2009, 02:28
А я тут в Стокгольме смотрел на Спешик за 4600 еуро! :sh_ok: Красава, блин! Токмо модель не запомнил... :smu:sche_nie: Задний мортер там в переднем треугольнике, под верхней трубой. А моск через трубочку на заднем пере.
Индеец
Сообщение Индеец » 01 мар 2009, 19:09
Это эпик 2009 года. Красавец. Через пару недель приедут к нам, но только карбоновые. Сам езжу на стамджампере алюминиевом. Лучше байка пока не встречал.
Сообщение BWN » 02 мар 2009, 17:45
Игорь писал(а):А я тут в Стокгольме смотрел на Спешик за 4600 еуро! :sh_ok: Красава, блин! Токмо модель не запомнил... :smu:sche_nie: Задний мортер там в переднем треугольнике, под верхней трубой. А моск через трубочку на заднем пере.
Это скорее всего Эпик, у них с 2009 года так.
А велосипеды нужно было покупать в 2008 году! :hi_hi_hi:
Сообщение BWN » 07 июл 2009, 15:22
Велик на Токсовском марафоне 2009
Велик катит, я пока не очень-)
Weloy
Сообщение Weloy » 07 июл 2009, 17:22
То есть велик катит без вас.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 43 гостя
